Replacing cartridge in an Alpha 2
dave123
Member Posts: 67
I've got an Alpha 2 circ 15-55 that needs it's cartridge replaced. I rec'd the new one, and there are instructions from grundfos in the box, but they don't seem to address the alpha catridge. All the other circs have an open space on the back, to tap out the old cartridge, but that area in the alpha is covered by the electronics and touch controls. I've tried prying gently at the rear covers, but haven't gotten them to open, and don't want to damage the controls. I've searched all over trying to find a description of what to do, but haven't found one. Anyone here had experience with this?
Thanks.
Thanks.
You may not want to use your favorite pocket knife... it should pop out easily.
Did it seize up? What type of boiler and piping. I'd like to see deeper inside where the rotor goes into the can. that is a bit tougher to separate.Bob "hot rod" Rohr
Living the hydronic dream1 -
I have been thinking about getting this exact pump to replace my Taco 007 in my radiant heat multi zone valve system. How long have you had it and it needed to replace the cartridge ?0
Great pump...However,The life of any circulating pump depends on how it they are being treated!VancouverG said:I have been thinking about getting this exact pump to replace my Taco 007 in my radiant heat multi zone valve system. How long have you had it and it needed to replace the cartridge ?
1. System fluid: Since these are wet rotor circs they do not like suspended Ferrous materials.
2. Power conditions: Like anything with a chip they do not like Power surges, Spikes .
3. Mounting positions.
Probably some other things that i am forgetting.
Word of caution! If you currently have a PBV you need to isolate or remove it..0 -
The rotor is magnetic and doesn't come out easily from the can.0
It's all about the fluid quality, that is the biggest variable in circ life. With ECM and auto adapt at least you don't run them way off curve.
The Alpha really isn't a replaceable cartridge design.
The Alpha 15-55 are being replaced with the 15-58EBob "hot rod" Rohr
Living the hydronic dream0
- 15.8K Strictly Steam
