Herman Nielsen Invisible Radiators ~1930
jlt83
jlt83 Member Posts: 11
Does anyone know of any potential sources for parts for the radiators housing / vents. I have a house full of these radiators with broken damper gears / control knobs and some missing the entire radiator “face”.
    Steamhead Member Posts: 18,453
    Herman Nelson was merged into Amercan Air Filter some decades ago. These units have been out of production at least that long. You'd probably have to have something custom-made.
    Post some pics if you can.
    Consulting
  • jlt83
    The mechanism I'm trying to repair is the screw and gear assembly pictured.
    Jamie Hall Member Posts: 27,305
    The teeth look OK, and the engagement... what is it they aren't doing, or needs repair?
    hot_rod Member Posts: 27,405
    A good machine shop can replicate most any part. 3D printers can do amazing replication also in most any material.
