Small Boroscope
Grallert
Member Posts: 1,130
Hi all. I very often have to clear very old drains here. The building I take care of is coming on 100 years old is of masonry block construction. All of the plumbing it set in stone so to speak. In other words there is no access to any or very little of the piping. I rely heavily on the building plans but they only get me so far. I thought a borescope might be helpful in determining the lay of the piping land. I see a ton of them on line and it gets overwhelming. Do any of you use one of the little hand held types and can make a recommendation? This is something I'm likely to use a few times a year, although I might find more reasons to use one if I had one.
What length do you need
Really no more than 15'. Most of what I'd be looking at is 1 1/2 up 2". Every5thing quickly connects to 4"
I use this one, but only for dry stuff (running wires). You need to use the app and look at your phone. For wet stuff you may want one of the ones with it’s own screen
https://depstech.com/products/wifi-endoscope-wf028-dual-lens
Thank you Steve. This what I have been looking at. Boy there's a ton of them out there. The price is right.
MMiss Hall's School service mechanic, greenhouse manager, teacher, dog walker and designated driver
I just ordered a DEPSTECH endoscope. It was cheap enough the take the risk on. It'll get used one way or another. My main concern is will it get through ancient 1 1/2 galvanized pipe and around corners... We'll see
I find these useful for a few feet. Had a cheap one but it wasn’t clear enough to help. Got an articulating (eg you can steer it like your doctor steers her colonoscopy) scope from Amazon. I think the brand was Teslayong or something but just read reviews focused on image quality and look for pictures in dark places close up (lighting and focus both matter). 15 feet is optimistic, maybe if you attach it to wire puller tape or something to help guide….1
I just saw this one, I think I may have to upgrade...
https://youtu.be/M5eOgeWWjs0
https://www.trutechtools.com/teslong-td500-articulating-endoscope-inspection-camera.htmlThere was an error rendering this rich post.
Ooooo I do like the flex option.
- 120 Geothermal
