Pvc exhaust
Pamelawardjohn
Pamelawardjohn Member Posts: 2
Why would water pour from pvc exhaust pipe on my Cyclone 100 a.o Smith boiler
  • Pamelawardjohn
    It happens when we try to fill it back up
  • JUGHNE
    JUGHNE Member Posts: 11,391
    You mean that when you try to fill the tank with fresh water, water comes out of the exhaust pipe at the bottom of the WH?
    There is a cond drain port on the bottom of the exhaust elbow, is that where the water exits?
    If so the burner compartment may be compromised.
    You might need a pro.
  • Zman
    Zman Member Posts: 7,611
    I have seen that happen in that model when there is a leak in the heat exchanger. I would have someone qualified look at it, but I suspect you will need to replace it.
    Albert Einstein
  • JUGHNE
    How old is it? Look for warranty possibilities.
    Have you opened the inspection ports in the past?
  • Derheatmeister
    Derheatmeister Member Posts: 1,651
    Does it leak when the Waterheater is off/not producing hot water?
    If it only leaks when it is operating it may be flue gas condensation which is nomal..
    Zman
