Borrow Code Books?
Rizz861
Member Posts: 64
in Gas Heating
Hello,
Im trying to take the NH Service Technician Gas fitting Exam. They require outdated books for the exam, 2015 NFPA 54 and 2014 NFPA 58. I have 2021 NFPA 54 and 2020 NFPA 2020. Using the books I have will probably result in incorrect answers because of code changes in newer books. You have to use a physical copy, no digital and no print outs. I really don’t want to drop $200 on two books I’ll only use once. I understand it’s all about what NH has currently adapted for their code, but I see no wrong using a more modern and astringent code which is why I bought these newer versions. Do you guys know of a way I could some how borrow these older books to study for the test and use them to take the test?
