Adding bedrooms where Radiant ceiling is
leewalter
Member Posts: 8
Hello everyone I’m in the start of remodeling our basement in a 1972 home that has radiant ceiling heat I. The basement and on the main floor, my wife and kids love it compared to our old house that had central HVAC because there was no moving air just heat. I was wanting to add 2 bedrooms downstairs but one of the walls will cross a heating panel that’s in the ceiling 4in wide and 5ft long, will that cause trouble with the panel because of heat/fire possibilities
Potentially. What type of radiant heating do you have, electric or water? Do you have a drawing which shows the routing of the lines?0
It’s electric 220, the top of the drywall says National Gypsum Company and the grid is built into the drywall with nail markes and the areas to not screw into printed onto the drywall.0
Key thing is to avoid nailing into a line. Other that that worst case is reduces or uneven heat between room. Can you post a picture / diagram of the heating areas and planned wall layout?0
Shots from further back would be helpful. Along with a room layout.0
I’ve got an inferred camera and can see the heating grids in the drywall plus the drywall after the popcorn is scrapped off shows the factory nail prints on it there are two panels that cross where I would like to add a wall,black are the panels and red is where I would like to add a wall.0
The wall layout is dependent on if we can put a wall across the radiant panels, there is supports on both sides even if we could not tie into the floor joist and “float” that section across the panels but I was wondering about heat buildup and or transfer to the wall structure that crosses the panels0
Just a crazy idea....even off the wall you might say...get it?
Perhaps build your wall with double top plates.
Just leave the upper top plate out where the panels are.
You SR your wall up to the ceiling and mud tape as usual.
The missing top plate would not cover any panel and prevent potential overheating and nail penetrations.0 -
That was a thought but I was wondering about creating a heat pocket inside that area0
Thank you0
I’d install large nail protection plates under the sections where the wall intersects the heating elements.0
