Pressuretrol switch failing. Replace, switch, unit or upgrade to vaporstat?
Bodycount
Member Posts: 43
As title states, PSI is inconsistent (0-3.6), if I tap the housing it will cut off the boiler.
I’m thinking of a vaporstat for better control.
Thoughts?
Tnx. Tom in NJ
Tnx. Tom in NJ
It would be good to know your definition of "better". The vaporstats are just as wildly off as the pressurtrol, so that aspect they are no better. The only possible advantage is a lower range, but one of the ones on mine would actually go above the top of it's range right out of the box. It's so off I had to ignore the scale, set it on the bench to the pressure I wanted then install it. After all that, my properly sized boiler never gets above a few ounces so none of them ever activate anyway. Which leads to my next comment...
For anyone that comes along to read this, the best solution overall is to have the boiler sized correctly when installed so these safety devices don't turn into operating controls.0 -
It's probably set too low. Happens all the time when my guys get overly ambitious with turning it down. Raise the pressure so the bottom of the indicator is just touching the top of the 0.5 line.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1
- 50 Industry Classes
