What’s your favorite radiator vent?
I would be interested in knowing you guys thought on radiator vents too.0
Gorton. Most simple design, consistent construction, made in USA by a nice company. A little slower to close but last forever. They make me a star when I replace a house full of Chinese vents with theirs. I make my living specifying Gortons. Bought thousands of them.0
Helpful Ed LOL
As a homeowner, I still prefer Maid O Mist. The mechanism is basically identical to Gorton (I believe Gorton copied it, don't @ me) and they are less expensive and they have swappable orifices for easy resizing.
If they didn't exist I'd choose GortonNJ Steam Homeowner.
I do what I can to helpethicalpaul said:Helpful Ed LOL
The Hoffman reps swear their design is superior to Gorton when it comes to handling vapor and excess condensate. I mostly use Gorton though. I like the product line even though it is oddly enumerated as numbers 4, 5, 6, C, D, 1, 2.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
I had 10 Hoffman 1A's brand new on my radiators.JohnNY said:The Hoffman reps swear their design is superior to Gorton when it comes to handling vapor and excess condensate. I mostly use Gorton though. I like the product line even though it is oddly enumerated as numbers 4, 5, 6, C, D, 1, 2.
They would randomly stop venting due to a droplet of water in the venting orifice / hole.
I fixed it by blowing in them with a can of air with the straw but it was annoying.
I switched all of them for Gorton's nearly 10 years ago. The problem still happens, but very rarely. Maybe once a season vs once a week with the Hoffmans.
Why this is, I have no idea, but I guess it's a downside to running really low pressure.
My main beef with the Hoffman 1A is it's terribly sloppy adjustment cap that makes the numbers useless. A great idea, terrible execution. I have to think a long long time ago the caps fit correctly.
That said, since it's mentioned here,
Does anyone know that Gorton actually manufacturers their vents in New Jersey?
Gorton has the vents manufactured entirely in the USA.ChrisJ said:Does anyone know that Gorton actually manufacturers their vents in New Jersey?
Maid-O-Mist vents are made in China.
We do institutional work so our major clients cannot purchase China-made products.
Me ...Hoffman when you see them ,Gorden when you don't...
Depends on where the vents are to be installed.
Main floor where the thermostat is, kitchen and bathroom- Hoffman #40, VentRite #11 or appropriate size Gorton up to #6 depending on how big the rad is.
Bedrooms- Vent-Rite #1 since they're so easy to adjust.
The Gorton #6, C and D are also useful as main vents on short mains.
Consulting0 -
I was recently told by a pro that I don't have to replace my radiator vents as long as they are blowing air and not wet steam. And all seven of my radiators heat up pretty quietly (some much slower than others). I have no idea when they were replaced, at least not in the last ten years. But they all seem to work, pretty quietly and no water comes out of them. But I've seen posts here that state they need to be replaced every 5 years or so. I currently have vent rites #1 on all of my radiators. Any thoughts on if they should be replaced?0
I made this chart a few years ago to show head to head some of the valves available. For my 4 unit 100 year old rental I spent some time with Maid o Mists, but pretty much converted to Vent Rite#1s for the low end venting and Heat Timer Varivalves for the higher venting radiators. My tenants don't mess around with the vents, so it's easier on me.
One surprise of sorts is that the Varivalves don't completely shut off venting.
In the last about 10 years, I haven't had problems with my radiator vents (that I remember).
I don't have any experience with Hoffman's, so I can't comment on them.
Good luck.
2 -
Good luck.
Interesting that I apparently could use Heat Timer varivalves on most of my radiators according to your chart.
I have everything from 4's to C's on my system, but most are 5's 6s and Cs.
IMO The Gorton #5 is the perfect starting place, so a Varivalve meets that apparently.
Well, that's not good.Long Beach Ed said:The VariVents have a HUGE failure rate.
What are the most common ways they fail?
Heat-timer VariValves have a nice copper bellows mounted in the top of the valve. Steam boils the alcohol in the bellows at 150 degrees and it expends, pressing a pin into a seat below, closing the flow. Some bellows deform and falls out of their mounting. Then it sits on the seat blocking the flow whether it is open or closed. If you shake one and it rattles, this is how it failed.
We installed hundreds of them, of which some 20% - 30% failed in the first year. Examining the failure, we reported it to the manufacturer, which had no interest in correcting the problem. It seems our remaining 60% are still functioning fine 15 years later.
A nicely designed valve but with a flaw.0 -
I like a valve with a float just incase the boiler overfills
The water's going somewhere. Better not to have an autofill.Big Ed_4 said:I like a valve with a float just incase the boiler overfills
Vari-valves are nice, chunky little fellows that I am sure are well made (They are a Fine American company that makes the Great Control) , and I've seen them perform ok on very dry steam. However, on many systems that have them, they can GUSH hot 🔥 condensate on your legs as you walk by like a faucet! I've also rarely seen the adjustment do ANYTHING to vary the heat. They ARE nice and heavy
And they bring nice Mongo prices when you "catch" a bucket of em....Mad Dog 🐕0 -
You don't think those cheesy little valves and the steam system could hold back 40-80 psi of water?ethicalpaul said:I like a valve with a float just incase the boiler overfills
We've had the same experience.JohnNY said:The Hoffman reps swear their design is superior to Gorton when it comes to handling vapor and excess condensate. I mostly use Gorton though. I like the product line even though it is oddly enumerated as numbers 4, 5, 6, C, D, 1, 2.
Have 13 radiators 9 of which use Hoffman 1a's. I have had the house for 20 years and suspect most of the vents were 20+ years old when I moved in. Have had only 1 failure back early on when I didn't know anything about steam and was cycling on high pressure. Replaced it with a MoM and it failed nearly immediately. Lowered pressure and replaced with another MoM and 6 months later it failed again. Replaced it a third time with another MoM and it has been fine since. Replaced a couple of the bedroom radiators with VentRite 1's because I wanted those slow. I prefer adjustable vents because from time to time the needs in the house change and I need to make adjustments accordingly. I have no issues with the reliability of the Hoffman 1a's. The Ventrite has only been on for 5 years but has been good as well.0
The Hoffman 1As I had looked beautifully made.dabrakeman said:Have 13 radiators 9 of which use Hoffman 1a's. I have had the house for 20 years and suspect most of the vents were 20+ years old when I moved in. Have had only 1 failure back early on when I didn't know anything about steam and was cycling on high pressure. Replaced it with a MoM and it failed nearly immediately. Lowered pressure and replaced with another MoM and 6 months later it failed again. Replaced it a third time with another MoM and it has been fine since. Replaced a couple of the bedroom radiators with VentRite 1's because I wanted those slow. I prefer adjustable vents because from time to time the needs in the house change and I need to make adjustments accordingly. I have no issues with the reliability of the Hoffman 1a's. The Ventrite has only been on for 5 years but has been good as well.
Just the sloppy adjustment cap with the useless numbers that I didn't like. The vent it self seemed solidSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
