Hydronic Contractor
Mitchell01
Member Posts: 1
Looking for a Hydronic Contractor to replace a Utica Hot Water Boiler in my home in the Elkins WV,26241 area
Look up any plumbing company that calls themselves XXX Plumbing and Heating. that is your first clue to a plumber that also understands heating systems.
here are 3 that I found
This is not a recommendation, I know nothing about any of these companies. I just wanted to give you a short cut to rule out Plumbers that may not understand Heating Systems.
tubs and toilets have not controls or exhaust pipes that take special understanding.
I always suggest contacting a hydronic rep for the area. They visit hundreds of jobsites in a year and know who is doing hydronics correctly. Or not.
Wholesalers also, especially if they have a hydronics design person in house. Auer Steel, First Supply, Ferguson are a few brands with locations across Wisconsin.
In small towns the hydronic gurus tend to be "underground" small shops that don't advertise, word of mouth operations. Often 1 or 2 man shops.Bob "hot rod" Rohr
Living the hydronic dream1 -
hot_rod said:I always suggest contacting a hydronic rep for the area. They visit hundreds of jobsites in a year and know who is doing hydronics correctly. Or not. Wholesalers also, especially if they have a hydronics design person in house. Auer Steel, First Supply, Ferguson are a few brands with locations across Wisconsin. In small towns the hydronic gurus tend to be "underground" small shops that don't advertise, word of mouth operations. Often 1 or 2 man shops.I’ve tried contacting my rep and wholesaler and I’m the closest contractor they know of.
The problem is that hardware stores and lumber yards used to be the suppliers for boilers in many parts of West Virginia. Since the state has now tightened up code enforcement, a good hydronic contractor is hard to find in the rural areas.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
You may have to pay extra to get the right guy out. When I had my full time boiler installation operation rocking and rolling, we would do out of area and out of state jobs several times a year. It was a challenge but they made it worth our while.
If someone is willing to pay you 50-100%
More than your going rate, pack the box truck, grab your coffee and go!! Mad Dog1
