Steam vent valve tongue
twix
Member Posts: 17
Do steam vents NEED a tongue for condensate? I'm looking at adapters like this one and they say they are compatible with steam, but do not have tongues.
https://www.supplyhouse.com/sh/control/product/~product_id=013G0140
This one says 1-pipe compatible, and install instructions do not say anything about a tongue.
Is it the end of the world if there is no tongue?
It shouldn't matter at all. Most vents don't have the tongue.1
Actually, I see this in the documentation for the valve:The venting action occurs during each system (boiler) on-cycle only
when heat is required. Air will re-enter the radiator during the system
off-cycle via a patented “‘across the seat” vacuum breaker. This
eliminates condensate build-up and allows natural system aspiration
to occur.0 -
Probably not the end of the world. In fact, Many have used them without even a tremor.twix said:
Is it the end of the world if there is no tongue?Edward Young Retired
Excellent! Thank you. So providing I'm not running a full vacuum system (I'm not) and the rad pitch is correct, I should be ok.0
I have the valve you posted on my system, zero issue. Also, none of my regular vents have a tongue and zero issues. So yes, you should be ok.1
Thanks everyone.0
- 50 Industry Classes
