Steam vent valve tongue
twix
twix Member Posts: 17
Do steam vents NEED a tongue for condensate? I'm looking at adapters like this one and they say they are compatible with steam, but do not have tongues.
https://www.supplyhouse.com/sh/control/product/~product_id=013G0140
This one says 1-pipe compatible, and install instructions do not say anything about a tongue.
Is it the end of the world if there is no tongue?
  • KC_Jones
    KC_Jones Member Posts: 5,916
    It shouldn't matter at all. Most vents don't have the tongue.
    2014 Weil Mclain EG-40
    twix
  • twix
    edited January 2023
    Actually, I see this in the documentation for the valve:
    The venting action occurs during each system (boiler) on-cycle only
    when heat is required. Air will re-enter the radiator during the system
    off-cycle via a patented “‘across the seat” vacuum breaker. This
    eliminates condensate build-up
    and allows natural system aspiration
    to occur.
    EdTheHeaterMan Member Posts: 11,773
    Probably not the end of the world. In fact, Many have used them without even a tremor.
    twix
  • twix
    Excellent! Thank you. So providing I'm not running a full vacuum system (I'm not) and the rad pitch is correct, I should be ok.
  • KC_Jones
    I have the valve you posted on my system, zero issue. Also, none of my regular vents have a tongue and zero issues. So yes, you should be ok.
    twix
  • JUGHNE
    JUGHNE Member Posts: 11,527
    The condensate build up is the water in the rad not returning without the vac bkr letting air into the rad after boiler cycle.
    This has been discussed here somewhat.
    With your vent vertical it should drain any cond that might build up within it.
    twixmattmia2
  • twix
    Thanks everyone.
