2 pipe gravity return question
Heat65
Member Posts: 10
I believe that is a vapor system ore even a vacuum system. Never came across one but others have on this forum. Look at this post from several years ago:
https://forum.heatinghelp.com/discussion/comment/1506713#Comment_1506713Edward Young Retired
Thanks Ed, if I’m reading the piping diagram correctly the relation to my boiler water line is way off, pictures below.0
That's a Webster "Type R" Vapor system, assuming the radiator fittings and air trap are also Webster. The Return Trap is covered in chapter 15 of "The Lost Art of Steam Heating", which you can get from the Store on this site.All Steamed Up, Inc.
Consulting0
- 50 Industry Classes
