For your amusement - chatgpt session for boiler question.
EricPeterson
Member Posts: 290
If you've not heard of it, chatgpt is an online AI (Artificial Intelligence) system that you can try out and ask questions of. I gave it a spin.
My takeaway is that only #2 is a viable answer. #1 and #3 concern protecting the boiler from overheating (which is NOT the question), and #4 is of minimal use.
In fact #1 and #3 don't even make any sense to me.
So I guess the machines are not quite ready yet to take over the world!
I am not advocating for this technology, but it's interesting to try new things.
Eric Peterson
Q: How do I protect my boiler from low temperature return water?
A: There are a few things you can do to protect your boiler from low temperature return water:
Eric Peterson
- Install a low temperature bypass system. This system allows a small amount of water to bypass the boiler when the return water temperature is too low. This can help prevent the boiler from overheating and potentially causing damage.
- Use a mixing valve. A mixing valve mixes hot water from the boiler with cold water to produce water at a more moderate temperature. This can help prevent the boiler from being subjected to extremely low temperature water.
- Install an aquastat. An aquastat is a device that measures the temperature of the water in the boiler. If the water temperature drops below a certain point, the aquastat will shut off the burner to prevent the boiler from overheating.
- Insulate the pipes. Insulating the pipes that carry the return water to the boiler can help keep the water at a more moderate temperature, which can help protect the boiler from low temperature water.
Close, too bad it’s gibberish. But it’s just close enough to trick someone who doesn’t know what is what.
“If the water temperature drops below a certain point, the aquastat will shut off the burner to prevent the boiler from overheating”
Okay 👌 if it’s too cold make it colder?
Unfortunately, some one, hopefully not many will take these as gospel.Bob "hot rod" Rohr
I guess if it said “if the water temperature drops below a certain point, the aquastat will shut off the burner to prevent the boiler from condensing”
That might be more accurate but still wouldn’t help the house heat up.0 -
It should be the aqustat shuts of the circulator to protect the boiler--low limit not high limit0
- 117 Geothermal
