Taco VR20-H Error Code E54
johnseawright
Member Posts: 1
Good Morning,
I'm a rep looking for explanation of the unlisted E54 error code on Taco VR20-H.
Circulator continues to ramp down after being set in constant pressure mode at 40'H. No other control wiring - jumper across enable. Performed a factory reset so we will have fresh error codes Monday but prior codes were E51 & E54. I know the VR is protecting itself but I'd like to better explain why?
This sounds like a job for TACOMAN
TacoMan... Faster than a speeding air vent
TacoMan... More powerful than a Beckett Burner
TacoMan... Able to leap tall radiators in a single bound.
Disguised as @Joe Mattiello Mild mannered trainer for a great metropolitan pump manufacturer
Fights a never ending battle for truth, justice , and secret error codes.
Was the motor taken away from the casing before install? Typically see these errors when the contractor disassembles the motor from the casing before install with the volute attached to the piping. This should be done on a bench to ensure correct alignment. Please give Taco Technical Services a call during normal business hours Mon-Fri 8am-5pm EST 401-942-8000.1
If only you knew a Taco rep that could help you get after hour/ weekend servicejohnseawright said:Good Morning,
Say hello to the team, happy new year!Bob "hot rod" Rohr
Living the hydronic dream2
- 116 Geothermal
- 15.8K Strictly Steam
