Lennox Pressure switch
Please help. Have an issue with 2 stage pancake pressure switch. No exhaust blockage. When the black positive hose is disconnected from switch the furnace seems to operate fine. I can blow freely in the positive line at receiver. Red line I’m unable to blow through at the receiver. Should I be able to blow through both receiver lines freely?  Could there be a blockage in the red hose line going into the receiver or are you not able to blow through that line. Thank you so much!!
    EdTheHeaterMan Member Posts: 12,179
    Insufficient information. Do you have model number of the Lennox.
    Are blowing thru the tube at the switch or are you blowing out the tube to the furnace?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Yes it should be free , use a paper clip to clear the tap .....
