Lennox Pressure switch
Jfawson
Member Posts: 1
Please help. Have an issue with 2 stage pancake pressure switch. No exhaust blockage. When the black positive hose is disconnected from switch the furnace seems to operate fine. I can blow freely in the positive line at receiver. Red line I’m unable to blow through at the receiver. Should I be able to blow through both receiver lines freely? Could there be a blockage in the red hose line going into the receiver or are you not able to blow through that line. Thank you so much!!
Insufficient information. Do you have model number of the Lennox.
Are blowing thru the tube at the switch or are you blowing out the tube to the furnace?
