Can anyone help me identify what pipe this is?
bs1026
Member Posts: 4
Here are the last two pictures of said solder joints sorry they did not post0
Congratulations on your vast knowledge after only 7 years.
The fitting looks like a standard compression fitting. Used on bigger pipes almost everywhere outside North America.
Is the pipe with the compression fitting the same pipe with the soldered elbow?There was an error rendering this rich post.
Measure the diameter. If it's copper it would be 5/8, 7/8, 1 1/8, 1 3/8, 1 5/8 or 2 1/8
If it measures the same od as black pipe it could be brass pipe but it doesn't look like it
or it's black pipe which it looks like with a silver soldered elbow0 -
Hi, You might be able to get by, simply by removing the compression nuts, cleaning things up a bit, wrapping with teflon and replacing the nuts. If the pipe is actually steel with a brass connector, carrying fresh water, there is galvanic corrosion going on. The leak may be caused by rusting of the steel. If it's standard sch 40 steel pipe, I'd consider installing a union or coupling with reverse threads. The soldered 90 may have been someone getting creative with acid flux.
Yours, Larry
ps. Does a magnet stick to that 90?1 -
It looks like a pipe product called sometimes called "Bundy" pipe.
It *was* copper coated thin steel.
It thereby could be soldered with copper or brass fittings... once or maybe twice.
It was used in the US for heating pipe, usually radiant.
Horrible stuff to repair.
Compression fittings are your friend.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc1 -
We called that "Tube-alloy" on Long Island. It was used extensively in the 1950s on residential heating. Dan talks about the Long Island Heating Menorah. It was a brass manifold with multiple ports that were home runs to hot water convectors. There are still many of these installed and working in towns like Franklin Square and Wantagh, Seaford. It was somewhat bendable, came in like a 1/2* OD and much to my amazement the first time my father in law showed me it, this steel-looking allow could be soft soldered! That first picture you posted is some kind of dresser coupling for copper to Tube-alloy. Ma Dog.0
I agree about soldering it Gordo but found that if you cleaned the hell out of it, got it really shiny, with clean flux and silver-bearing soft soldered like Silva'Brite or Taramet Sterling and didn't overcook it, you were golden mad Dog0
That coupler looks like a pack joint or similar. Often used underground but can be used inside.
The original ones used lead packing but they use rubber now.https://youtu.be/o434Q41khg0
Heres a pack joint picture.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
The Compression coupling is on the same pipe as the soldered elbow , sounds like most of you have seen this type of pipe before and the best course of action is to either replace with a new compression fitting or clean the rusted pipe very well and solder with low heat , one of you mentioned sterling solder I believe that's what I carry it comes in a purple and yellow box correct?0
Chris J it looks exactly like that without the female threads0
Those aren't female threads they're grooves to grip the pipe when you tighten the clamp. You need to watch the video I posted.bs1026 said:Chris J it looks exactly like that without the female threads
Here's the one I installed on my new water service though it's threaded male on one side and pack joint on the other.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
