Crown boiler
I have a crown boiler, model AWI095. Sounds like it cuts out for a split second while running. What are possible causes?
Also, not sure if this helps, there’s two very small lights blinking. One green, one amber.
Thanks!
    EBEBRATT-Ed Member Posts: 20,173
    Pictures would help. Sounds like you low water cutoff. This may be normal depending on what control you have
