Electrical wiring of emergency shut off switches
2»
  • 65cobra
    65cobra Member Posts: 1
    I have a setup as you show in the second drawing. I would like to add a pilot light to the switch that only has 2 wires in the box. Can this be done? Thank you
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Not correctly as you have no neutral at that location.
    There is however a single pole switch that lights up when off.
    Would show up in a stairwell.
