Electrical wiring of emergency shut off switches
I have a setup as you show in the second drawing. I would like to add a pilot light to the switch that only has 2 wires in the box. Can this be done? Thank you0
Not correctly as you have no neutral at that location.
There is however a single pole switch that lights up when off.
Would show up in a stairwell.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
