cold radiator
fr12
Member Posts: 2
I have 1 upstairs radiator that is not producing any heat, I've change the air vent and check to make sure the radiator is pitched back to the valve, I changed out the main line vent in basement to. all of the radiators in the rest of the house are working, Anyone have any suggestions?
I assume that you have ensured that the inlet valve is, in fact, open? It's happened... Does any heat get to the inlet pipe? If not, how far from the main up the riser does it get? Is everything pitched correct.y?Br. Jamie, osb
Valve could be broken or disk fell off in pipe.
With the boiler off, take the air vent off then start the boiler if you get air then steam you will know. Take the vent off when cold and put it back on when cold so you know you can do it when the steam comes up.
Don't get burnt or ruin the curtains0 -
Thank you, I'll give it a try later in the week when things warm up.0
How about pitch of the runout pipe?gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1
- 117 Geothermal
