Can anyone identify this valve for me?
rnn9
rnn9 Member Posts: 9
edited December 2022 in THE MAIN WALL
I have two radiators in my house that have this valve on it. The rest have a regular valve on one end and a pipe on the other end.  The two that have these valves are located at the end of the heating loops.
  • Danny Scully
    Danny Scully Member Posts: 1,462
    Hmm, I don’t know the specific model but it seems to be similar to honeywells unique valve. I’d bet the pipe on the right has a dip tube that goes into the radiator a few sections.
    EdTheHeaterMan Member Posts: 10,581
    I believe the valves name is Victor. Victor T. Valve to be exact. I met him at the supply house in 1938.
    PC7060Long Beach Ed
    mattmia2 Member Posts: 13,014
    Is this hot water or steam?
  • rnn9
    Hot water.  I put a new close up picture.  Still can't make out who the manufacturer is.
    I have seen a picture of the inside of this valve somewhere. If I recall correctly the inside of it looks like this.
    PC7060
  • rnn9
    Any Idea why this type was used at the end of the heating loops instead of the two pipes that were used on all of the other radiators?
  • bburd
    bburd Member Posts: 1,166
    Probably as simple as something in the way of piping to the other end, or maybe the installer just had those valves on the truck.
    Are you having trouble with them?
    Bburd
    PC7060
  • rnn9
    One radiator doesn't get that hot compared to the others, but that may just be because it's at the end of the loop. It also is on a Navien combi boiler that is not always heating the water up to the temperatures it was originally designed for.  For example, today the water temperature out of the boiler is 135 degrees and it's 27 degrees outside. The old boiler was always at 160 - 180 degrees no matter what temp it was outside.
  • bburd
    That sounds like a flow balancing issue. If you have a multi speed circulator, you might try setting it higher if possible.
    Bburd
    EBEBRATT-Ed Member Posts: 17,969
    @rnn9
    if your water temp is only 135 it's probably something else in the system besides the radiator
  • rnn9
    Navien is adjusting the custom heating curve based on what it was programmed to using the outdoor temp sensor.  It keeps the house at 72 degrees and is working quite efficiently.  Even when we were down to 5 degrees the last two days.  On those days I'm sure the water temperature was near it's max at 160 degrees.
  • rnn9
    This radiator is in the coldest part of the house and has two large single pane windows from 1911.  So maybe the 180 degree temp just was able to mask the drafts better than the low temp.  It must also have to do with it being at the end of the loop.
  • rnn9
    Bburd.  I have a three speed circulator on the system.  Increasing the speed does get that radiator to a higher temperature, but it also decreases the delta T which I assume will decrease the overall efficiency of the boiler. IDK It just might be something I'll have to live with.  Would this type of valvw have anything to do with the temperature difference?
  • bburd
    I don’t believe that valve has anything to do with it, so long as it is fully open and not broken internally, so as to obstruct the flow. That radiator is probably a bit small for the load in the room, and its location at the end of the system is compounding the problem.
    You might try reducing flow to some of the radiators in the warmer parts of the house, to send more flow to the cold room.
    If it were my place, I’d raise the circulator speed. You may sacrifice just a bit in efficiency, but it’s probably a worthwhile tradeoff for a comfortable house.
    Bburd
  • rnn9
    I'll try that.  Maybe just increase the speed when it's very cold out.
  • SlowYourRoll
    SlowYourRoll Member Posts: 187
    why don't you do a rubbing with pencil and paper to see if you get a clearer look at the manufacturer.
    rnn9
  • rnn9
    This is what I got from that.
    SlowYourRoll
  • SlowYourRoll
    well so much for that idea
  • PC7060
    PC7060 Member Posts: 1,664
    Use the side of a sharp #2 pencil; try to lightly shade over the entire name plus 1/2” all sides.
