Can anyone identify this valve for me?
rnn9
Member Posts: 9
Hmm, I don’t know the specific model but it seems to be similar to honeywells unique valve. I’d bet the pipe on the right has a dip tube that goes into the radiator a few sections.0
Is this hot water or steam?0
Hot water. I put a new close up picture. Still can't make out who the manufacturer is.0
Any Idea why this type was used at the end of the heating loops instead of the two pipes that were used on all of the other radiators?0
One radiator doesn't get that hot compared to the others, but that may just be because it's at the end of the loop. It also is on a Navien combi boiler that is not always heating the water up to the temperatures it was originally designed for. For example, today the water temperature out of the boiler is 135 degrees and it's 27 degrees outside. The old boiler was always at 160 - 180 degrees no matter what temp it was outside.0
That sounds like a flow balancing issue. If you have a multi speed circulator, you might try setting it higher if possible.—
Bburd0 -
@rnn9
if your water temp is only 135 it's probably something else in the system besides the radiator0 -
Navien is adjusting the custom heating curve based on what it was programmed to using the outdoor temp sensor. It keeps the house at 72 degrees and is working quite efficiently. Even when we were down to 5 degrees the last two days. On those days I'm sure the water temperature was near it's max at 160 degrees.0
This radiator is in the coldest part of the house and has two large single pane windows from 1911. So maybe the 180 degree temp just was able to mask the drafts better than the low temp. It must also have to do with it being at the end of the loop.0
Bburd. I have a three speed circulator on the system. Increasing the speed does get that radiator to a higher temperature, but it also decreases the delta T which I assume will decrease the overall efficiency of the boiler. IDK It just might be something I'll have to live with. Would this type of valvw have anything to do with the temperature difference?0
I don’t believe that valve has anything to do with it, so long as it is fully open and not broken internally, so as to obstruct the flow. That radiator is probably a bit small for the load in the room, and its location at the end of the system is compounding the problem.
You might try reducing flow to some of the radiators in the warmer parts of the house, to send more flow to the cold room.
If it were my place, I’d raise the circulator speed. You may sacrifice just a bit in efficiency, but it’s probably a worthwhile tradeoff for a comfortable house.—
Bburd0 -
I'll try that. Maybe just increase the speed when it's very cold out.0
rnn9 said:
This is what I got from that.0 -
Use the side of a sharp #2 pencil; try to lightly shade over the entire name plus 1/2” all sides.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
