B&G PR Valve - Other Makers options
0ldHous3
Member Posts: 1
I am replacing my Bell&Gussett FB-38 PR Valve and (since I am so new at this) wondering if there are other manufacturers or models out there that are made better. I noticed that B&G changed their materials from brass to something "lead-free" that looks and feels lighter and cheaper. Also apparently new valves corrode faster.
There is TACO Cast Iron valve that seems comparable - Anyone familiar with this manufacturer or cast iron vs brass usage?
Thanks in Advance
Thanks in Advance
You want brass because it is feeding city water. Taco, Caleffi, B& G and Watts all make them0
It is the same part... All that LF means is that the brass parts that touch the water are lead free brass. This is because the state of California has found that lead is harmful to your health. And as California goes so goes the rest of the country. Looking for your electric car yet?
@EBEBRATT-Ed ... I think CASH ACME make them also. Just in case you are working for a Coyote.
wasn't nixon from ca as well?0
Clean water act started during the Ford administration.mattmia2 said:wasn't nixon from ca as well?
In 2010 California included lead free flux and solder 2% and the wetted surface formula for any plumbing brass component. All manufacturers chose to use that formula, so it got everyone on the same page as far as what "lead free" really meant.
There is no lead free brass. Else it would no longer be brass. The % of lead has been reduced, other alloys blended in to replace the missing brass. Low lead brass is the better terminology.Bob "hot rod" Rohr
Living the hydronic dream0
- 117 Geothermal
