Oil Guage (petrometer) - Is it accurate before or after you push the 'button' on top
Yes to waht @EBEBRATT-Ed and @leonz said. Looks like it is time to order an oil delivery
The shop that made them was still in Lindenhurst NY a few years ago ..
You had to break the chain Ed...Big Ed_4 said:The shop that made them was still in Lindenhurst NY a few years ago ..
looks like the model 1329 PetroMeter. https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Petrometer - 1329-112 - Brochure.pdf
I have 2 customers that still have them in service. And yes the company still makes them.
The old one this place came with had a square dial and a plunger located on the bottom.0
Could be a stupid question and I think I've asked before but I can't remember.
Is there any reason no one ever uses a gauge glass like on a steam boiler on an oil tank? Wouldn't that be much simpler and always dead accurate vs all of the convoluted contraptions they sell?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The level gauge mentioned in this post is for buried tanks . Glass on above ground tank ? I would be afraid , pressure alone from a oil delivery , 42' gauge glass and glass . I recommend the Rocket type gauge for COD home owners .
Big Ed_4 said:The level gauge mentioned in this post is for buried tanks . Glass on above ground tank ? I would be afraid , pressure alone from a oil delivery , 42' gauge glass and glass . I recommend the Rocket type gauge for COD home owners .
Gauge glasses are used on industrial boilers and steam engines and even standard ones are rated several hundred psi at high temperature, but sure..... Pressure from an oil delivery is scary.......
I don't believe that the high pressure steam boiler glass tubes at lengths over 36" with the associated fittings and tank tappings are practical when the Scully econo-gauge is so inexpensive.
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
