rinnai M090CN time program error
superman3652
superman3652 Member Posts: 1
I received an error message on my rinnai M090CN that reads
Time Program Error: Time Program service type mismatch. enter into technical menu and check it.
I am not an HVAC guy, I did however install the boiler. I am unable to figure out what this is stating.
  • Couldn't find anything in their user manual. Sounds like a reminder to service the boiler.
  • nephologue
    nephologue Member Posts: 1
    Did a solution get found for this? I have the same error and even factory reset won’t help
  • LennyAM
    LennyAM Member Posts: 1
    I have the same issue on my Rinnai M120SN
  • AndythePlumber
    AndythePlumber Member Posts: 111
    From the home screen
     -press ok
    -scroll to complete menu-press ok
    -scroll to screen settings-press ok
    -scroll to time program service type-press ok
    -there are two options here-change it from whichever you’re initially set on.
    -the boiler will restart and you’ll be all set
    -should it reappear, you’ll need to replace the board and/or the display.
    -I’ve seen this on two separate installations and each time this procedure cured the issue
    THINK
