rinnai M090CN time program error
superman3652
Member Posts: 1
in Oil Heating
I received an error message on my rinnai M090CN that reads
Time Program Error: Time Program service type mismatch. enter into technical menu and check it.
I am not an HVAC guy, I did however install the boiler. I am unable to figure out what this is stating.
Couldn't find anything in their user manual. Sounds like a reminder to service the boiler.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Did a solution get found for this? I have the same error and even factory reset won’t help0
I have the same issue on my Rinnai M120SN0
From the home screen
-press ok
-scroll to complete menu-press ok
-scroll to screen settings-press ok
-scroll to time program service type-press ok
-there are two options here-change it from whichever you’re initially set on.-the boiler will restart and you’ll be all set
-should it reappear, you’ll need to replace the board and/or the display.-I’ve seen this on two separate installations and each time this procedure cured the issueTHINK
1
