Hallmark B-168 blower cradle bearings
Bear2
Bear2 Member Posts: 3
Old Hallmark B-168 working fine but the blower makes a loud rackety sound when it slows down and looking for a pair of blower rubber bushings/cradle bearings for the repair. Any guidance on locating the bearings or input for the repair is appreciated.
    EBEBRATT-Ed Member Posts: 19,605
    You have to slide the whole blower assembly out.
    As I recall there are only a couple of different size rubber enclosed bearings. Any HVAC supply house should have them. W W Grainger has them. Looks like Zoro has them on line
    If the shaft is bad then that should be replaced as well
    Bear2
  • Bear2
    Thank you.
    Does anyone know what size bearings?
    edited December 2022
    Find a source for the bearings and measure the shaft diameter. Have them available before you pull the blower out and return what you don't need.
    Google: WW Grainger and look for insert bearings. Click on the rubber enclosed ones they have a chart with all the sizes. Most of them the dimensions are close enough so they will probably all work if you get the shaft size right
    Bear2
  • Bear2
    Many thanks!
