Hallmark B-168 blower cradle bearings
Bear2
in Gas Heating
Old Hallmark B-168 working fine but the blower makes a loud rackety sound when it slows down and looking for a pair of blower rubber bushings/cradle bearings for the repair. Any guidance on locating the bearings or input for the repair is appreciated.
Thank you.
Does anyone know what size bearings?0 -
Find a source for the bearings and measure the shaft diameter. Have them available before you pull the blower out and return what you don't need.
Google: WW Grainger and look for insert bearings. Click on the rubber enclosed ones they have a chart with all the sizes. Most of them the dimensions are close enough so they will probably all work if you get the shaft size right1 -
Many thanks!
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
