venting 404 liberty gray water from slop sink
Are you asking about a Liberty-enclosed sump pump installed under a mop sink?
If you are, I'm not entirely sure what you are describing here.
What I will say is that all of these types of sump pump setups need to be vented into the atmosphere.
If they are not, (using a Studor, sure vent, or plugging the vent? )The pump, because it is enclosed in its own tank, will not discharge because it will get caught in a sort of vacuum lock.
So. the vent should not be drained into the sink to catch overflow as you asked.
Does this help? Or am I not reading you correctly?0 -
you can vent it back into the main sewer line using a studor vent go to there website there is a diagram it also works for sewage ejectors. i coundnt load your pictures so i was unable to see if main sewer was close0
I am also unable to download the installation instructions.
However. The instructions do verify what I have previously posted.
@Fizz .....google the directions for that pump. You will find on page three, Item "B" states that they do not recommend using any type of air admittance valve. The performance will be hindered. In my case many years ago the pump would not work at all. ( I had to read the directions later ) Whoops.
Anyway. Google it up and follow the recommended instructions. You can't go wrong. Good luck.0 -
The air admittance valve breaks the vacuum. The problem is with the pressure from the water filling the basin, that needs to vent somewhere. I guess that is what the tie in to the stack is doing(although if I'm not mistaken there is a vent in that space that could be tied in to directly.)mikedo said:when you tie the vent back into the top of the sewer you break the vacuum and it will function. ive done it many times also works on sewage ejectors so you dot have to go outside with vent
- 50 Industry Classes
