p-wtgo-6 water content
mikedo
Member Posts: 296
does anyone know how much water this boiler holds its a wiel mclain. tech support has a 2 hr wait and the distributor cant find it in literature
18.4 gallons on page 42:
https://www.weil-mclain.com/sites/default/files/field-file/Weil-McLain_WTGO-Brochure_Series3.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
About 18.4 gallons
thank you i was looking online but could not find it needs antifreeze. its slightly oversized 6 section in an 1700 sq ft ranch0
That is way more than slightly. If I was guessing I'd say it's 3-4 times the size required for that house.mikedo said:thank you i was looking online but could not find it needs antifreeze. its slightly oversized 6 section in an 1700 sq ft ranch
2 -
Maybe you could let it freeze and see if the insurance company can get you a new boiler. The correct size boiler.KC_Jones said:
Disclaimer: This is not a real suggestion
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
