p-wtgo-6 water content
mikedo
mikedo Member Posts: 301
does anyone know how much water this boiler holds its a wiel mclain. tech support has a 2 hr wait and the distributor cant find it in literature
  • 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
    EdTheHeaterMan Member Posts: 11,783
    edited December 2022
    About 18.4 gallons
  • mikedo
    thank you i was looking online but could not find it needs antifreeze. its slightly oversized 6 section in an 1700 sq ft ranch
  • KC_Jones
    KC_Jones Member Posts: 5,916
    That is way more than slightly. If I was guessing I'd say it's 3-4 times the size required for that house.
    2014 Weil Mclain EG-40
    EdTheHeaterManHVACNUT
    Maybe you could let it freeze and see if the insurance company can get you a new boiler. The correct size boiler.
    Disclaimer: This is not a real suggestion
