Laars mascot 2 no hot water
Cbrown18
Member Posts: 2
hello
i had a lockout - and reset
I then ran through all the setting as it’s been a while since we used the heat.
Now the heat is working but the hot water is not. The relay clicks on but when you turn on a hot water faucet - it does not luck I’m fir anyone hot water
many idea what to check now - but getting any codes
thank you thank you I’ll start down that road0
- 167 Indoor-Air Quality
