Can a thermostatic valve be added with the current valve and piping
sinkus
sinkus Member Posts: 4
    Jamie Hall Member Posts: 27,196
    Don't see those very often... that is an ingenious arrangement which allows one to run hot water radiators with only one end coupled.
    I don't see any good reason why you couldn't cut a thermostatic valve into one of the pipes. What you can't do is replace the existing valve and connections.
    Intplm.bburd
    EBEBRATT-Ed Member Posts: 20,056
    Agree with Jamie the old valve will have to stay
  • KC_Jones
    KC_Jones Member Posts: 5,926
    2014 Weil Mclain EG-40
  • sinkus
    Thanks for the information Jamie!
    mattmia2 Member Posts: 16,382
    There is a Danfoss valve with a a lance and I think another one from another manufacture that could replace that vale. The thing is the Honewell Unique valve is also a bypass so if you stop flow to that valve, anything else in series will also not heat. If it is separately connected to the mains then you can install a TRV before the unique valve(or in place of), otherwise you need a bypass.
  • sinkus
    Thanks Matt, it is fed right off the main.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,504
    Never seen that.  Where is that job?  Mad Dog
  • sinkus
    New Jersey
