Touch less faucet question
My sister is having a strange issue and I have no experience with these faucets.
It's a 3 hour drive to her house and it's difficult to figure out over the phone..
They're having issues with showers getting cold even though there's plenty of hot water and it seems like we've traced it back to the kitchen faucet....
It's a touch less faucet that apparently you set the temperature using it's single handle but then it turns on and off electrically?
Are there times these faucets allow cold water to flow into the hot side? I would assume there must be check valves of sorts? Do they get clogged easily? Is this a common problem or are we barking up the wrong tree?
This is the faucet in question.
hot_rod said:Must be some device between H&C to prevent crossing over My son installed that exact valve. It doesn’t like me, or it is my operator error. So I end up turning on the handle anyways😂
And sadly I think Matt is right I don't see any signs of check valves. It looks like they added a solenoid into the hose of a normal faucet.
How is that even possible especially at that price tag?!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Looks like the check valves are a separate part. Did whoever installed it install them?
https://media.deltafaucet.com/PartsDiagram/DPD-K-9197T-DST Rev I.pdf1 -
mattmia2 said:Looks like the check valves are a separate part. Did whoever installed it install them? https://media.deltafaucet.com/PartsDiagram/DPD-K-9197T-DST Rev I.pdf
I don't think they go in the supply hoses.
But I had thought the same thing you did initiallySingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
see step 3:
https://media.deltafaucet.com/MandI/106559 Rev D.pdf
if installed by the same "handyman" that installed the dishwasher in my friend's apartment that threw out the safety pan1 -
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
