Touch less faucet question
My sister is having a strange issue and I have no experience with these faucets.
It's a 3 hour drive to her house and it's difficult to figure out over the phone..
They're having issues with showers getting cold even though there's plenty of hot water and it seems like we've traced it back to the kitchen faucet....
It's a touch less faucet that apparently you set the temperature using it's single handle but then it turns on and off electrically?
Are there times these faucets allow cold water to flow into the hot side? I would assume there must be check valves of sorts? Do they get clogged easily? Is this a common problem or are we barking up the wrong tree?
This is the faucet in question.
From what I've been told by them it's a normal faucet handle and it needs to be on. The electric part is in the faucet hose not the actual hot/cold valve handle.hot_rod said:Must be some device between H&C to prevent crossing over My son installed that exact valve. It doesn’t like me, or it is my operator error. So I end up turning on the handle anyways😂
And sadly I think Matt is right I don't see any signs of check valves. It looks like they added a solenoid into the hose of a normal faucet.
How is that even possible especially at that price tag?!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Looks like the check valves are a separate part. Did whoever installed it install them?
https://media.deltafaucet.com/PartsDiagram/DPD-K-9197T-DST Rev I.pdf1 -
It doesn't show them in the instructions but what I got from it is they're installed either in the hose to the spray head or in the spray head. Both of them in series to act as a backflow device because the head could be in a full sink etc and potentially backflow.mattmia2 said:Looks like the check valves are a separate part. Did whoever installed it install them? https://media.deltafaucet.com/PartsDiagram/DPD-K-9197T-DST Rev I.pdf
I don't think they go in the supply hoses.
But I had thought the same thing you did initiallySingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
see step 3:
https://media.deltafaucet.com/MandI/106559 Rev D.pdf
if installed by the same "handyman" that installed the dishwasher in my friend's apartment that threw out the safety pan1 -
- 50 Industry Classes
