Marketplace Headline of the Day!
Josh_S
Member Posts: 17
I had to share, this is hilarious! Can anyone spot the issue?
You can use them for hot water. With somewhat reduced heat output. The bottom section of the radiator would get hot. May be good for someone who likes to look of an old style radiator but does not need all that much heat. And at least one section would heat up up until the air vent. And of course if you installed it upside down, that section would get even more heat.1
Rethinking the upside down installation. Might not get that much heat. Bottom part would fill with water but incoming hot water but only circulate across the top. Bummer0
Steam only0
For the sake of clarity, and to protect myself from liability, my comments above were meant in jest.0
We have found that radiators without top connections can work in a hot water system. We have worked on the now hot water heat system in Pullman's Florence Hotel (Pullman train cars) and they reused a number of Reed type steam radiators on the main floor. These heat fully top to bottom. The Rolairtrol must slowly pull the air out of the water over time as the system absorbs it from the radiators.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
