What kind of gloves
jacobsond
Member Posts: 93
Looking to find a good glove for working on steam. Mine is commercial (state college heating) running 80lbs on the main piping and 8 after the PRV on the low side. My leather gloves work good for heat,but get a blast of steam and oh man got to get those things off. I tend to not wear the gloves as much as i should and the hands are starting to show it. Most of the work is on the 8lb side. Working on traps and heating coils. I get the occasional puff of steam and of course the drop of water that makes a mark. Never work on anything live. Always isolated with a valve that never quite seals all the way. Any suggestions on a glove t that will protect better and you can still turn a wrench?
Probably the kind firefighters wear may help.
Check with the local fire department for used ones.
Even our small dept would get upgrades pretty often and we had a pile of slightly used gloves.
The older ones would get stiff, but a little steam work will soften them up.0 -
- 50 Industry Classes
