Hydro therm
bucka002
Member Posts: 1
in Oil Heating
Old oil boiler Hydro Therm model OH 105. Not firing up. Leaking oil under at rear? Pump?
Let's start at the beginning:
Is the power turned on?
Is there fuel in the tank?
Is the thermostat calling for heat?
Does anything operate? Motor? Circulator?
Do you have a MultiMeter to check for electric current?
Have you pressed the reset button? If yes... DO NOT PUSH IT AGAIN
When you pressed the reset button, did anything operate for a short time?
Oil burners can be very dangerous.
If the fuel pump is the " Pump?" you are talking about, and there is fuel oil leaking on the floor, You should not operate the burner until you have a oil burner professional repairman look at it
,Edward Young Retired
I guess @bucka002 must have spent a Buck or 2 to get it fixed over the weekend.
1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
