Williamson boiler burner turns on & off
nytech28
nytech28 Member Posts: 116
i checked  Williamson hot water boiler, burner cycles on & off, to troubleshoot fast, I swapped control board & ignition assembly with similar model boiler, but same results , I unplugged gas valve seems to be getting 24 volt's, once gas vavle connected back burners fires up & off , can this be gas vavle issue ?
    EBEBRATT-Ed Member Posts: 20,173
    Who knows? Could be anything including the gas valve. Throwing parts at it without troubleshooting what you have is just guessing
