circ pumps circulators
b & g series 60 in-line pumps
differential across pumps is 10-15
one pump is 40-45 what is causing higher differential
  • ScottSecor
    ScottSecor Member Posts: 1,026
    Higher pressure differential equals more restriction/ head.
    In other words the pump with the bigger difference on pressure is working harder to move the water.  Most often this is due to a longer run, more restrictions,  etc
  • bburd
    bburd Member Posts: 1,293
    Or partially closed valves.
    Bburd
    hot_rod Member Posts: 27,275
    Plugged strainers
