3 way valve-diverting or mixing
creger.robert
creger.robert Member Posts: 108
can anyone explain exactly how this 3 way valve works
  • ScottSecor
    ScottSecor Member Posts: 1,031
    I think the arrow on the left side of your drawing may be oriented the wrong way.
    If I'm correct,  P4, P5 and P6 may require lower water temperature?   I'm guessing the mixing/diverting valve allows some water to bypass.
    On second thought, we need to see the system returns and how they tie in.
  • ScottSecor
    Maybe a few photos would help.
    hot_rod Member Posts: 27,335
    Possibly labels on the valve A, B & AB.
