1013- 200 control with B&G 100
inspkerr
Member Posts: 23
Hello, replaced my old control module on an 1991 weil Mclain HE2 series 1 the new 1013- 200 integrated boiler controller manual says it requires a 120 volt isolation relay to work with my B&G 100 circulator - would that be a Honeywell R845 relay? THANK for your help - Paul
I just replaced a 60 year old Honeywell RA832A with a Resideo/Honeywell R8845U (the indicated replacement) mainly because I needed the "C" wire. "DO NOT BUY A RESIDEO!" Very poor quality control. It took 3 of them until I got one that worked. Get the TACO version. So in between shipments, I rewired the 832 and to give me the "C" wire and still worked great. But I thought maybe it's time for a new one just in case. AND you have to make a 120v jumper to get the power to the correct terminals. The TACO has a jumper built in with the terminals numbered/arranged appropriately for logical wiring. The jumper can easily be removed. All the relays are "Dry Contact".
I had a B&G 100 for 60 years and the coupling went. I have fixed it myself once and a replacement is $10-15. But we have a warranty service that is suppose to take care of that stuff now. They took the B&G 100 and replaced it with a TACO 007. We're freezing and the TACO Engineers are furious that plumbers do that. They said it should have been a 0010.
tldr: 60 year old B&G 100 on a 60 year old RA832A worked great. B&G 100 on newer TACO version should be just fine.1 -
Thanks Bob
The control mod. sheet says its rated for a maximum of 3 amps for the circulator circuit, This controller was not cheap and I don't want to harm it, so I'm kind of nervous about plugging the series 100 directly into the controller. So you think RA832A is my best bet?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
