8 year old steam, possible leak
Snowmelt
Snowmelt Member Posts: 1,454
I went to a new customer 8 year old steam boiler, was put together with minimum piping (tomorrow I will take pic of the piping) was called for t stat not working but I went in boiler room, only one main vent on one of the two risers, auto feed was at 230 gallons. ( I reset it) in3 hours used about 12 gallons but it took about an hour to get pipes hot and lots of soot on the burners. What causes a boiler to leak prematurely?
    Steamhead Member Posts: 18,475
    Mostly excessive water use. Look for leaking vents, packing nuts etc.
    Consulting
  • Snowmelt
    Your right I never looked in any of the rooms I was staying in the boiler room.
    Would it make sense to put 2 main vents on both sides of the return ?
