Honeywell VF06 feeder question
superxfly
superxfly Member Posts: 3
The boiler in my house has the Honeywell VF06 water feeder. There is a red knob on the bottom of it. Is that knob supposed to be open or closed in normal boiler operation? Thank you.
    EBEBRATT-Ed Member Posts: 19,299
    Instructions attached. They do not say which way to turn it. I would assume clockwise (looking from the bottom) would be off and counterclockwise would be on.
    This is a controversy. Some will say (me included) to keep it on and some will say keep it off. Most keep it on.
    superxfly
  • superxfly
    Thanks for the help. I did find this diagram of the valve and to me , it looks like it has to stay open.
    The handle on the bottom is a manual on-off. The top controls the pressure setting. It does not have to stay on but that is the way they are most often used
  • Big Ed_4
    Big Ed_4 Member Posts: 3,338
    Look like a bad spot to install it , how can you service it ?
  • superxfly
    That’s the way it was when I purchased the house. It will be a pain to service, but I’ll leave that to a professional.
