Passing water on my McDonnell & Miller Electric Water Feeder
The site glass on my boiler keeps over-filling and I suspected water was either passing by the main valve or through the 24v McDonnell & Miller automatic Water Feeder. The main water supply line was cut in two section to determine where water was leaking and you guessed it - The Water Feeder. Not a lot, but enough that confirms my huntch of where the water has been coming from.
Does anyone know if these can be repaired or not?
    EBEBRATT-Ed Member Posts: 20,185
    The instructions are attached. Clean the strainer and the valve. Most prefer the Hydrolevel feeders which can be rebuilt
  • neilc
    neilc Member Posts: 3,183
    the cover is upside down and won't hold the water in (?)
    known to beat dead horses
