Weep hole
Snowmelt
Member Posts: 1,454
One of my friends asked me about weep hole in a radiator shut off valve. The only answer I had was so the zone doesn’t freeze and has just enough flow of hot water not to freeze. So my question is does all radiator shut off valves have weep holes ?
While on the subject, same friend is going to install a Weil McLain water boiler, in the directions the flow check valves where on supply and return? I told him that’s like wearing suspenders and a belt.
Thanks in advance guys
Depending on the piping arrangement flow checks may be necessary on the supply and return, you can get gravity circulation within the pipe on the side without the flow check in some situations.0
Old school hot water hand crank valves have small 1/4” hole to allow flow even when closed to reduce risk of freezing lines. That’s how you can tell a steam valve, close fully with no hole.0
Often there is either a zone valve, of a circ in one end of the zone, so really only one check is neededSnowmelt said:One of my friends asked me about weep hole in a radiator shut off valve. The only answer I had was so the zone doesn’t freeze and has just enough flow of hot water not to freeze. So my question is does all radiator shut off valves have weep holes ? While on the subject, same friend is going to install a Weil McLain water boiler, in the directions the flow check valves where on supply and return? I told him that’s like wearing suspenders and a belt. Thanks in advance guys
If you have a single pump systems with zone valves in the returns, check in the circulator, you are covered also.Bob "hot rod" Rohr
Living the hydronic dream0
- 50 Industry Classes
