Recommendations for replacement controls on a residential boiler system
Boilershepherd
Member Posts: 29
The existing controls are being decommissioned. Modified Tekmar reset control mess.
I'm asking for advice for a replacement system that can manage a hodge-podge build.
there are five zones: on a weil mclain cast iron 200,000 BTU (guess), taco 007 circulator.
two are valved with white rodgers 1361 zone valves.
one is the DHW. no additional circulator.
the second, the cast iron radiators on the two living floors. no additional circulator.
The other three are radiant floor installs, wirsbo wax motor, two wire, 24V
There had existed a mixing valve controlled with a tekmar model.
Also, an additional circulator for those radiant zones.
The mixing valve has been long since siezed to a temp and is just left in place.
Zoning with the WR valves can work with a Taco zone control.
I wish to be able to open the radiant zones on a call and delay that circulator long enough before it starts. This I cant seem to design with the same control.
Id like one control, does it exist?
I think i can do i with one taco zvc406, one sr504 and upgrade the wax motors to four wire.
If I gang the radiant end switches into a Taco SR 501-EXP instead of the Sr504 maybe I can make this.
I found it like this.
No pressure. Juicy leaks. Blank controls. Mixing valve abandoned in place.0 -
Interesting. I'll study it in the morning, but I like the detail.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I'm having difficulty loading pictures.
@Boilershepherd, click on the document or image icon in the toolbar. Here are some more tips for using the forum: https://heatinghelp.com/forum-user-manualBoilershepherd said:I'm having difficulty loading pictures.President
HeatingHelp.com0
- 110 Chimneys & Flues
- 983 Plumbing
- 387 Solar
