Help decide on Mitsubishi split heat pump hyper heat or not
bluesjumper
Member Posts: 3
We are about to pull the trigger on purchasing four indoor and 2 outdoor heat pump units. Our master bedroom needs to be on a dedicated outdoor unit (cooling only) and the other three rooms (6 BTU in TV room and 15 BTU in living room on main floor, and 6 BTU in kids room upstairs) would be on the other outdoor unit. I'm a bit torn on whether to go with the Mitsubishi hyper heat series (FH) or stick with the GL series. From a cost perspective, it's nearly a moot point. I'm in Boston and there is a substantial MassCEC rebate that only applies to FH which would wash out the less cost of the GL system. My conflict is that the GL series is 5 inches smaller than FH which would be noticeable in the small TV room and kids room. But in a Boston winter, I could benefit from the hyper heat. GL series is only for 35 degrees. I heat my home with oil and there is also electric baseboard heat in the TV room and kids room which we'd no longer use once we get the heat pumps. Oil being so cheap right now (and my town's electric rates are very high) is also consideration.
Would appreciate any further insight into making the right decision!
Thanks, Vlad
Thanks, Vlad
I just had a 12k Mitsu Mr Slim heat pump installed for my first floor (600 sq ft). It's a mid range unit with a seer of 20 and an EER of 12.5 if I recall correctly.
They certainly don't give them away but I'll be interested to see how well it does at handling the shoulder seasons. It will never pay for itself but should be a good supplementary source of heat on late fall and early spring days.
3PSI gauge0 -
IIRC, when I was looking at the Mitsu units, the hyper heat cut the cooling efficiency significantly. Thsi may be a factor.To learn more about this professional, click here to visit their ad in Find A Contractor.0
They make the Hyper heat units to 30seer, but they are smaller single zones. Once you go to the multi head/multi zones the seer ratings drop. To 17 seer or so. But they will still be more efficient then standard heat pumps do to the inverter compressor and flash injection of refrigerant into the compressor to keep high discharge pressures in very cold out side air temps.0
Thanks for everyone's opinion. I'll stick with the hyper heat. It's a multi zone unit with 18 SEER.0
Look at the various areas that you intend to condition with the mini-splits. Compare the pricing vs the SEER/HSPF on the multis vs the singles. It was probably 2010 (todays efficiencies are higher), but I found it was better to do the bedrooms with a multi and the downstairs with a single high SEER unit. 16 seer/9.5 hasp on the multi back then and 25 seer/hspf on the single. It was a good combination.1
I installed a 12K GL single 5 years ago in our upstairs master bedroom cooling only. In an older remodeled farmhouse in NW Ohio. I have a boiler with BB. Works great, wife loves it. A month ago I installed a 9K FH with heat and cooling. It is a single unit also for an upstairs room. I went with the FH because in the winter we keep our room 60*. I figured if we use the other room as a guest room when family visits they may prefer warmer temps since both rooms are on the same heating zone. Price wasn't that much more. The indoor unit is about 5" longer. Not an issue for me. I'm glad I went that route now since my wife is looking at also using that room for here sewing and quilting room. Haven't seen how the heat will work yet. It's been 90* for the last week here. Our winter temps average about 30*, but we do hit 0* on design days. I know some are turned off by the looks of the indoor units. My wife was happy, that was 99.9% of the install. I am considering a multi unit for the downstairs to replace a 18.5K window shaker. I know they aren't rated as high SEER, but still quieter and more efficient. Just my experience. Mike0
Why waste your money on a unit designed to fail? All of my head units are corroding do to incompatible metals. Aluminum into copper. I have very bad corrosion after only a few years. These head units will eventually fail. There is no stopping it. I feel ripped off by Mitsubishi Electric!0
WOWK9ecollars said:Why waste your money on a unit designed to fail? All of my head units are corroding do to incompatible metals. Aluminum into copper. I have very bad corrosion after only a few years. These head units will eventually fail. There is no stopping it. I feel ripped off by Mitsubishi Electric!
You wrong, there not designed to fail!
Mitsubishi is one of the best but like everyone else they have had issues. What has your installing contractor done, have they been in contact with Tech Support, filled a warranty claim? That system has a 12-year warranty i believe.
Mitsubishi can't be accountable for environmental issues, improper install, lack of maintenance!2 -
I put hyper heat units in my house up in NH. My only issues is I with I did 2 outdoor units instead of one for the 18-6-6 heads I have.
When something breaks and parts have to be ordered or you develop a leak you won't regret it!dirtbike59 said:I put hyper heat units in my house up in NH. My only issues is I with I did 2 outdoor units instead of one for the 18-6-6 heads I have.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 983 Plumbing
- 389 Solar
