Understanding Static Pressure in my heating system.
JackW
Member Posts: 236
in Gas Heating
I'm trying to understand the static pressure readings of my heating system. I've watched dozens of videos on YT, but I still can't grasp what I'm reading. It's a downflow system; there is no A-coil, and the only obstruction is the furnace filter. As you can see in the photo, I have a hole above the filter and below the furnace. I've also included a picture, a bad one, with the w/c number circled. It reads 0.70 IWC or 0.174 KPA. A one-minute reading produces a .31 max, a .19 low, and a .26 average. Are these readings telling me anything?
Thanks,
Jack
Thanks,
Jack
Those hoses actually add to each other.JackW said:@ChrisJ, I have one below the furnace itself. Is that not the same?
The top one is measuring suction (before the fan) and the bottom measures pressure (after the fan). The gauge adds them together.
If you move the top one to just after the filter its going to show more pressure drop, sometimes a lot more. Right now you're measuring the suction before the filter is having an effectSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The open return is perverting the TESP. Close it with tight fitting magnetic strip, sheetmetal cover or removable tape.
What is that below the furnace? Looks like an A coil to me with my weak eyes.0 -
It certainly does look like an evap but it looks like a blank housing with no connections.Bob Harper said:The open return is perverting the TESP. Close it with tight fitting magnetic strip, sheetmetal cover or removable tape. What is that below the furnace? Looks like an A coil to me with my weak eyes.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@ChrisJ, so I need to drill a hole below the filter, and I don't need the probe above the filter? Do I need the probe below the fan, or do I just use one probe? What do you mean by "looking like an evap"? We don't have central A/C, so there is no A-coil.
Thanks.0 -
@Bob Harper, I don't know what you mean by "open return." We don't have central air, so they took the A-coil out when we replaced the old furnace a couple of years ago. Thanks for your help.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
